Mills561
BURR
I'm going to be running two amps, one for highs, one for lows. The high amp is already hooked up and I'm about to get started on hooking up the mono amp because I recently got a subwoofer. I have a question about the distro block... The one I have is from KnuKoncepts and one side has two 1/0 terminals and the other has three terminals- one 1/0 and two 4 awg. What would be the best way to go about running the wires? And would it matter if I have 8 awg power wire from the battery but used 1/0 from the distro block to the amp? 1/0 is the only thing I have laying around at the moment.
And just to make sure I'm right about this- I need to run two separate ground wires to each amp, correct?
