Question about big 3
I was just curious, so I will prolly only run 0 for the second alt and just keep the 4 + a 0 for the stock.
and im going with 2 110 amp alts becasue I can buy a second one for just over $100 core included.. now could I buy a HO alt with 220 amp for the same price? probably not lol
If you have the means to fabricate a bracket, 99% of the time it's cheaper to run dual stock alts than it is to run a single alternator that puts out the same amperage.
Do the big 3 in 1/0AWG. Should just help your charging system be more efficient.
The brackets will be easy, it will bolt on right over my power steering pump and I only need a bracket on the top witch i can bolt to the AC compressor. then just use the original stock alt to get the right tension on the belts //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Compjake
Chrysler guy
Compjake
White City, OR
Compjake
Mike Mccabe
