kyle187 10+ year member Member 95 0 02809 Jan 25, 2009 #1 If a amp is 100x2 does that mean 100 to 2 channels or 50 to 2 channels? Click to read more...
Doola36 10+ year member CarAudio.com Elite 2,001 0 SoCal Jan 25, 2009 #2 which amp are you referring to?
OP kyle187 10+ year member Member 95 0 02809 Jan 25, 2009 Thread Starter #3 this one http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18804
nineball 10+ year member too many toys... 1,949 0 home Jan 25, 2009 #4 taken directly from the description in your link: # 400-Watts RMS x 1-ch @ 4-Ohm # 200-Watts RMS x 2-ch @ 2-Ohm # 100-Watts RMS x 2-ch @ 4-Ohm
goingdef 10+ year member CarAudio.com Veteran 2,909 26 Norfolk VA Jan 25, 2009 #5 ok 2 channels bridge them and call it one channel its 400 watts rms use each channel for two subs if the subs are 2ohms each the amp will make 200rms to each sub if its 4ohms per sub the amp will make 100watts per channel make sense
OP kyle187 10+ year member Member 95 0 02809 Jan 25, 2009 Thread Starter #6 yea makes sence. I thought that if it was 200x2 then that means it would be 100 to each of those 2 channels, but thanks for clearing it up for me.
nineball 10+ year member too many toys... 1,949 0 home Jan 25, 2009 #7 it will depend on your subwoofer and it's voice coil configuration
OP kyle187 10+ year member Member 95 0 02809 Jan 25, 2009 Thread Starter #8 what if its for component speakers?
gunz4me 10+ year member Goodbye! 2,251 0 Louisiana Jan 25, 2009 #9 Only problem is with a name like Hifonics, I would tend to believe that it is slightly overrated! Granted, it may do 100 watts RMS at 1,000 Hz:laugh:
