Question about amp power wire size
geowick07
I searched around, but what i am looking for seems to be a little too in-depth for the search function to be able to find it.
I am trying to find out if it is OK to use 8 gauge power wire when it is listed as having 4 gauge power inputs. The amp in question is the Power Acoustik OV2-300; a link will follow if it helps. The amp will be used by a friend of mine on a set of components. The fuse is only 15a, and it will only be providing 70w x 2 @ 4ohms. Seems to me that 8 or even 10 gauge would suffice. But, i would like some advice!
Streetwires.com has a good interactive site to determine power wire requirements. Personally I would go with an 8ga. As evan stated you will not save much on going to 10ga. anyway.
You wont save a lot of money going with 10ga, at most like a dollar or two.
Go to wallmart and buy some of the scosche 8awg that would work good i use it for my 8ga.
I searched around, but what i am looking for seems to be a little too in-depth for the search function to be able to find it. I am trying to find out if it is OK to use 8 gauge power wire when it is listed as having 4 gauge power inputs. The amp in question is the Power Acoustik OV2-300; a link will follow if it helps. The amp will be used by a friend of mine on a set of components. The fuse is only 15a, and it will only be providing 70w x 2 @ 4ohms. Seems to me that 8 or even 10 gauge would suffice. But, i would like some advice!
so what happens when the upgrade bug bites,tell him to go with 4 gauge,he won't regret it
I would personally go with 4ga, just for head-room later in the feature. They're cheap anyways. You could get some from knukonceptz.com . Would you rather have too little/too small of a wire, or too much/too thick?
geowick07
geowick07
Warren, Michigan, United States
Radridd
