Question about Alpine X's
Andrew_as
My friend has a set of alpine type X's. It has the things you plug into it that change it from series to parallel. There is 3 places to plug the fuse looking things into. Middle one is series and the 2 on either side is parallel. The question is does it need one of them fuse things in both parallel slots or just one? Also He only has 2 of the fuse like things. So if it needs one in each parallel slot what else could we use for it?
Edit: I found that i need one in both parallel slots. So what else could i use since he only has 2 jumpers
yea i guess that would work too. But there is already a little piece of wire going from each other right now. are they spose to be there or has someone already done what your talking about?
Andrew_as
Andrew_as
Topeka, KS
jco1385
Mike Mccabe
