question about a new amp
thenewguy
AL
I want to upgrade from my current amp and I need to get one that will be able to power my two 15 inch subs with around 400 watts to each. I was looking at the power acoustics new LT Hyperbass I was wondering if it would have enough power or should I go with a more efficent class D mono amp for more money.
The specs....
4 ohms rms370x2 2 ohms rms 440x2 mono rms880
bridge max1920
Full Mosfet Power Supply
PWM Circuitry
Full Selectable Crossover Hi/Full/Low
Three Way Protection Circuit
2 Ohm Stable Stereo
Tri-Mode Capable
Variable Low Pass 30Hz-500Hz
Variable Hi Pass 50Hz-500Hz
Variable 24 dB Bass Boost
Variable Subsonic Filter 60Hz-200Hz
Frequency Response: 10Hz to 30KHz
S/N Ratio: 98 dB
THD: 0.02%
System Distress Indicator
4 Guage Power/Ground Connection
Diamond Cut Heat Sink
Gold Plated RCA Connectors
Line Output
Top Control Panel
ya I would have to say im on a cheap budget like no more than 220 and i have two 15s single voice coil i wanna wire them 2 ohms with around 400 rms and 1400 max
thinkin about going with lanzar heritage 2000 watt mono amp its come down from $389 to $220!!! i gotta jump on this I was please with my 1200 watt lanzar vibrant and I really dont need to upgrade but I want something new.
thenewguy
thenewguy
AL
thenewguy
NorthFramingham
    Jun 30, 2026
