Question about 2 and 4 channel amps
alexdbest2000
NY/Canada
Im going to be running 2 front comps to start off with to see how i like it, might eventually run 2 rear later on. Im thinking i might be better off getting 4 channel amp so i can run 2 speakers for now, and if i upgrade later on ill just use the other 2 channels for the rear. Any downsides to doing this? Should i just get a 2 channel amp instead?//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Nope. You can actually bridge the channels on the frts for more power to
If i dont bridge it there's no issues with leaving 2 channels empty?
And hmmm, bridging the channels would give 240 rms per chan on the amp i plan on getting... thats a bit overkill for comps, no? I plan on using boston pro 60's
Nice components. Set the gains at a lower voltage. Should be find
Personally, i'd get the 4 channel. More versatility for future upgrades. Plus you can bridge it and get more power if needed.
You cannot unless you wire the two speakers in series. If you wire them in parallel, that brings the load down to 2 from the speaker and the...
To be honest I don’t use anything. Haven’t carpeted a box in 20 years, I just leave them bare wood as I like testing stuff, swapping stuff around...
13
313
358
alexdbest2000
alexdbest2000
NY/Canada
alexdbest2000
saints747
    May 7, 2024
saints747
    May 7, 2024
