Q's on RE box..
yline58
got any clues about making port enclosures for '06 12" RE xxx?
But I wanted to go with SQL in box. So I had to figure the dimension size of box... if u have any ideas, just drop the msg and thanks for your all input details.
12”
Mounting Depth - 12.75”
Mounting Hole Diameter - 11.5”
Overall Diameter - 13”
Bolt Hole Circle - 12.25”
Motor Width -10.5”
Motor Depth - 5”
Basket Depth - 7.75”
Displacement - .24 cu. ft.
Weight - 72 lbs.
12”
Electrical Q Value -Qes: 0.460
Mechanical Q Value -Qms: 3.290
Total Speaker Q Value -Qts: 0.404
Free Air Resonance -Fs: 21.00 Hz
Equivalent Compliance -Vas: 74 liters
One-Way, Linear Excursion -Xmax: 54 mm
Efficiency -SPL 1W/1m: 83.76 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 4.2 ohm
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 2000 W
Force Factor -Bl: 18.16
whats the cu.ft. size for 12" xxx like i need to calculate the dimension and cuts off the per side? it will be playing in port and daily usage. tks
yline58
yline58
Canada
yline58
