Q 15 cutout
If its the same dimensions as the SSD (I think it is)
I can send you a cut out to trace if you want to pay shipping
EDIT: Yeah I have a template I can send you PM me if you want it just pay shipping
Allright good, thank god I didnt start cutting. I about did. Darkhunter, thanks for the offer but ill just measure it out also. Also one more question.............my sub is upfiring, the problem is that I did not mount the board tht houses the sub on top of the side walls. I mounted it inside the side walls. Will this have enough support?
I would maybe put some bracing in those corners. You may experience some flex or cracking with the weight of the sub though.
allright where do i find braces and how do i install them, better safe then sry. Does anyone know how much this thing weighs?
If its a 15", then obviously you make a 15" cut out //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The sub will fit perfectly IN the box
dpu2014
dpu2014
Indianapolis
darkhunter139
