Ok so I tried the settings and this is what I came up with. If I put in a dvd, and select 5.1 mode the bass goes way way down, not out of the speakers, just out of the sub. No matter what settings, double movie, music rear fill little to no bass comes from the sub. When I put the dvd in stereo mode on the dvd menu it self it says it's in lcpm mode on the info screen.
When dolby in the head unit screen is turned to off, then the pcm dvd level is the only option that changes over all sound level. If I put the dolby mode in rear fill, movie or music then the only function in the dvd level that adjusts the sound level is dobly digital.
It's black and white man. If you set the DVD menu to stereo, choose PCM in the processor settings. If you choose 5.1 in the DVD menu, set the processor to Dolby PLII for music or movie (doesn't really matter much between those two). Doing it flip-flopped is all wrong and will have significantly less output.
5.1 playback from the W205/H701 combo is significantly quieter than stereo. This is why you can adjust those levels on the front end, then set your gains, and then leave it alone.
In general 5.1 playback is going to be quieter than stereo in any circumstance simply because you don't have multiple speakers playing all of the material at the same time. You only have two separate channels with stereo, so everything that happens on the left comes from all left speakers. Everything that happens on the right comes from all right speakers. All low frequencies from either channel come through the sub. With 5.1, each speaker only plays a portion of the action. Most of the material comes from the front speakers. Your rears play very little, and your sub only plays material that was formatted during the recording process to come from the sub. Play something with big explosions, and you should notice the sub comeing to life at those times. Don't expect it to be anything like a rap song on the radio or a CD. It's just not going to be that way. You might need to adjust the subwoofer setting all the way up to 15 when playing back movies in 5.1 to be happy, but there again, to get any result from doing that, you need to leave you subwoofer setting lower than that (maybe 8 or 10) for playing music, or you won't have anywhere to increase. It's all about headroom. Leave yourself room to increase these levels when needed.
After playing with the settings I came up with a few conclusions.1. The head unit can take a lpcm sound track and make it a 5.1, and preserve the low bass.
No, it cannot.
2. The head unit and the processor fight each other so if you choose 5.1 in the head unit the processor for some reason doesn't play the subwoofer audio tracks.
That is not true.
3. The only way to get a 5.1 soundtrack to play on my current system is to leave the audio option on the disk menu to stereo because the processor will take care of the rest as long as I pick one of the dolby settings. I have sin city which has a dts soundtrack I'll give that a try and see if it makes a difference.
If you leave the DVD menu setting on stereo, then you are not getting true 5.1 from your processor. You need to match the DVD menu seting to the processor setting.
I'm sure I'm missing something. I'm still very very green when it comes to car audio, but I'm sure at some point I'll get to the bottom of it.//content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif :fro:
It is somewhat complicated, but I'm doing my best to help you understand how it works. It's tough sometimes to do that in text, whereas if we were both sitting in front of the unit I could show you what I am talking about visually and give you real examples of how the settings work.
In the end, I think you are expecting more bass output in 5.1 than what you will get. In order to make it as much like 5.1 in a home, you need to set things correctly, and this includes starting with your PCM level at 0 (or maybe even -1 or -2), and then setting your gains correctly with test tones and a DMM, and then maxing out your Dolby and DTS level at +5. If you do this first, and then follow the rest of the settings I laid out for you, you should be happier.
