PV Audio's Carpeting/Box Build Technique Tutorial *56k on hiatus*
lets say i wanted to carpet this ugly beast....http://i11.tinypic.com/3z7487o.jpg
and when i get to this fold..there is ton of excess "carpet"
http://i5.tinypic.com/2yoygbl.jpg
ive got to be doing it wrong....
...I have no idea as to what you did there. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
This is the easiest way I can describe to do this carpeting technique. Take a tissuebox, cut out squares of paper that are the size of the ends (the SMALLEST rectangles). Then, wrap paper all around the main part, and then trim off the edges. Same concept here, but you're tucking it into grooves instead. You have three separate pieces of carpet (two identical sides, and the main piece).
oh!!!!
so you tuck two sides correct?
like....2 light gray ( 2 carpets)
and 4 dark gray (one carpet)
*color coding it*
i hope im right //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif????????
oh!!!!
*color coding it*
Yes, the four main sides of the box are all one piece of carpet. Hope that's what you're asking //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
not what i was asking...but its what i needed to hear...thank you.
and when that one main part of carpet comes together, do i just overlap a lil? or cut close to it as possible?
quote me for your 16,000!!!!!!!
lol
When the main part comes together on the bottom, you overlap the carpet a few inches. You then lay down a straight edge (carpenter's angle in my case) across the entire width of the box. You then want to run the razor along the straight edge through BOTH pieces of carpeting. That way, you will cut off the open end, and cut through the already glued portion, so that when you peel off the glued portion, you have a perfect seam. That's the most difficult thing to illustrate since you can't see the seam.
how does it feel to have posted 16,000 times?
thanks man
No problem. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Lol, I'm not even in the top 10 of posters here though.
you just need 1000 more.
haha
but sry...i dont wana ruin your thread.
on topic
PV Audio
The Vision of Sound
PV Audio
Indy
PV Audio
