PV Audio's Carpeting/Box Build Technique Tutorial *56k on hiatus*
Fisher made a thread like this for his method. I merely adapted it since I don't like using my router if I'm just making a sub box. If it's a home speaker, then fine. If I want to sit there and take days to weeks on it, sure. Otherwise, I want it to be on the customer's doorstep ASAP.
As a noob someone that would have liked to follow that tutorial you left out a lot of details that make that tutorial useless for me....
but the box looks awsome.
What did I leave out? You could have at least told me what it needs instead of just saying it's useless.
what's so difficult about it, I think it pretty straight forward... very basic.
good work BTW PV
Yea, the only parts I left out were the final steps of actually building the box, but as I said, I don't recommend doing this unless you know how to drill into MDF without splitting it.
300 > all btw
And yes, a table saw makes all the difference when it comes to efficiency. Make sure that you get a GOOD one, not the cheapest one. They are not made equal and I had to buy the hitachi you see here after getting ***** by a craftsman one.
300 > all btw
thanks bro...
i made a new thread about table saws...help if you can...
pretty good tutorial bro. i like the presentation of the information, is very easy to understand and the pictures explains it all by them selfs.
thats exactly how i do all my carpeted enclosures. i figured most people used the same technique. since its so simple and you dont have to buy or use extra tool to do it.
one thing you have to keep in mind while you're assembling the enclosure is to clean up any glue that got into the grove. if you don't is going to be tricky to clean up after it has dried and if you don't clean it up the carpet will not go into the grove.
also here is an image of a jig i made to keep the blade from ever hitting the aluminum guide, its simple and very easy to make, and will keep your guide from getting damaged by the blade.
again great job on the tutorial.
http://img1.putfile.com/main/1/620185423.jpg
Mm, shoulda put that in there. Yeah take a flathead screwdriver and scrape out the glue when it's wet. I'll edit the post.
More details on your guide? If you can see in the pics, it took me a few tries my first time to not hit the fence. I just marked the width on the measuring tape now though.
And thanks for the compliments. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Ohh, I think I get you. You just take a 90 degree bonded piece of MDF and clamp it to the fence to make sure that if it does indeed hit, it hits the wood and not the metal. That's so simple, it's brilliant. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
PV Audio
The Vision of Sound
PV Audio
Indy
PV Audio
