Pushing Skar VVX-12s
ten_ton_bass
I just ordered 2 Skar VVX-12s in a custom ported box from Kevin at Skar. I'm gonna be powering them with the Skar 1500.1 amp that throws out 1680w at 1 ohm. This should push those subs pretty nice no?
Setup going in an '08 Impala SS. I hope it is loud enough. Impala trunk seems pretty sealed. Might have to drop the back seat.
As long as your electrical is descent, should get quite loud in the correct box. Just make sure you have a nice box built for their specs, and you should be good to go. I would always drop the seats, no matter how much power you have. Its almost always gonna make it louder.
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
305
796
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
983
ten_ton_bass
ten_ton_bass
Lacrosse, WI
The_Grimy_One
    May 24, 2024
