Punch p3 15 box?
4xGmc
Ok rockford says 2.25 @ 33 hz but doesnt that seem a lil small the recomend 2ft sealed thats what i got it in now it sounds desent but i want more output its being pushed off a saphire sp2x 1600 bridged it just seems verry weak for a 15" sub btw its in a full size van so space isnt an issue
WoW i said space wasnt a issue but man thats a lil over kill. Wouldnt cardboard be more suited. Maybe You could suggest i buy some realy expencive sub but sence i am stuck owning this pos sub i would still like to have it sound as good as possible untill i can buy a wonderwoofer thanks for the help
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
Class A/B, right? If I recall, these little 2x30 watt jems could best several hundred watts, mono. One of RF's endearing qualities on most of...
764
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
947
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
4xGmc
4xGmc
Columbus ohio
SilverSquared
    May 18, 2024
    May 16, 2024
