PSP aero calculator, and others:
silenkiller
I have a question about using the port calculators - when I add a port, lets say, two ports, the port length seems to always go up. Is it then that the port length on there is talking about TOTAL length? So the length given is divided by number of ports?
Also, what the benefit of more than 1 port? Less chance for port noise?
Thank you guys for helpen //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The length given is the length of EACH port.
The more port area you have, the longer they be to get the desired tuning.
2 4" ports need to be longer than one 4" port to get the same tuning and so on.
Now which you need depends on a few factors. Enclosure size, how much power you are running, what size/quantity of subs, and so forth.
More than one port has more port area. More port area=louder to a point. Less port area=punchier bass.
Ah alright. This gets tricky kinda fast. Cuz every exta port like nearly doubles the length. Oye. Alright thanks for shedding some light on that.
Should the end of the aero inside the enclosure be flared as well?
silenkiller
silenkiller
zz
silenkiller
