propper wiring of multiple batteries...
rtillaree
F***, Strong
anyone know where to find a guide here or want to explain to me how to propperly wire up multiple batteries, gonna go with a few kinetiks in the back...
i searched but i couldn't find anything wicked helpful, going to keep looking though just in case i dont get any replies //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
i dont see where it talks about wiring up 2 additional batteries, i want to strap 2 kinetiks together in my trunk...maybe i missed it...will read it again...
Positive to Positive,
Negative to Negative.
That's called Parallel wiring. This steps capacity, and is what you want to do in this case.
Positive to Negative to Positive to Negative
That's called Series, which is what you might find in your television's remote contol. This steps the voltage, and is not what you want to do here.
god this site gets dumber every day
if you dont knwo how to wire up multiple batts, you dont need a system that needs support of multiple batts
they need to be wired in parallel all the positives togheter
all the negatives togehter
just use an isolator from your hood battery to your trunkthen run whatever batts you have in your trunk in parallel with most likely 1/0 awg wire... keep it at 12-14 volts
You could do this if you don't mind the voltage drop across the diode in the isolator thats going to the batteries for your amps.
on bcae the diagram is at the bottom of the page on the section "battery isolators"
we belive u //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
i get the feeling that you have a false sense that anyone really gives a fvck what you say. no matter how many nut swingers hang out here:rolleyes:
rtillaree
F***, Strong
rtillaree
Orlando
prochobo
