Thanks man, it was a lot of work doing all the doors, and it made a world of difference for sure. It's one of the most important investments I have made in my truck audio-wise I believe. I was gonna do exactly what you were thinking too. I am gonna add sheet metal over the openings in the door and then recover with deadener and I hope the added stiffness will help get my midbass response up. Even with just what I have done so far, I was able to get the response down from around 80hz to mid to high 60hzs, but when I turn it up louder, the bass seems to just seems to disappear, lolIt looks like you have deadened the door pretty decent and done some work to deaden the panel itself. I would do the MLV and the closed cell foam. I would just make the holes a little bit smaller so you have to really work the clips back in. Im not sure how far you want to take this, but you have already done more than a good majority of people would do. Short of adding more deading and trying to add more mass/deading to the door panel, you are going to have to do something really custom to improve upon what you have already.
I believe it took about 40 sq feet for all 4 doors, but the front doors are a little larger than the back. And don't doubt it on these trucks, it's well worth it to deaden it!how many feet of deadner did it take to cover both your doors? Im about to do the doors of my 08 ram
I am looking into adding screws around the perimeter, only if I can figure out a way to make it blend in really well.Screws would be a horrible idea. Just put some foam back there. Believe me, you'll be kicking yourself in the *** in the future if you drill up those panels. Something i've learned with age is that some things are just better off left alone.
If it was a pos like alot of car's i've seen on here then I'd say do whatever the fu ck you want, this doesn't fall in that category.
I remember seeing somewhere (either autozone or Oreilly's) some self tapping screws that were in several different colors and had small plastic washers around the head. The only problem I couldn't figure out was they didn't look long enough to go through the panel and the deadener, MLV and CCF. They were only like 1.5" inches long. I have been searching since I got home for some that were longer than those, cause those would probably work well and blend in too. If I can find them, I will make sure I send you the link!I'm kind of in the same boat. I just CLD CCF and MLV'd my doors and I cant get those f'n plastic push pins to engage to the door to seal it. Right now, I just have the 2 bolts in the door handle and 1 bolt at the top of the door holding them on. If I were to go the screw route, would self tapping screws work?
You should be good then. A little off topic, but how do you like those Hertz front stage? I have heard great things about them.well i have a single cab so i only have the 2 front doors to do, but im gettin 25cuft
Joseph ... Bring your truck to me, I can fix you up with these doors (if you haven't taken care of this already) ...You should be good then. A little off topic, but how do you like those Hertz front stage? I have heard great things about them.
Thanks for the link Bro! That's the best price on butyl rope I have seen yet. I am still trying to figure out the easiest and cleanest way to get these door panels to work right. Since it will be for SQ competing, I am trying to not cut corners, but I don't won't to waste my time doing the unnecessary either. I found replacement doors at a junk yard for about $400 bucks, so if I end up messing up something with my "test" door, I probably won't have to pay thousands for a replacementYou can buy butyl rope from most auto parts stores or autobody supply places. Sometimes its called strip caulk :-/
They also make a cool product that is butyl setting tape.
CRL Black Butyl Setting Tape and Adhesive. CRL 1303 - Filmtools
Closed cell foam can be bought at upholstery shops or some fabric stores. Some major cities have foam rubber supply places that carry all types of foam. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I agree that a solid attachment like a screw would be best. However, if the clips are tight fitting and don't rattle, sealing with butyl rope/tape or foam should be adequate?
Really sounds good now with my doors done and DD T2's in the dash. Feeding em 90watts from a DB drive A5You should be good then. A little off topic, but how do you like those Hertz front stage? I have heard great things about them.
