klepto
Perveyor of Filth
So here's the thing. Im running two amps in my car, both of them in my trunk so i can ground them in the same place. For my 12'' Mag, im running a Massive P1000.1 @ 1ohm which is rated at around 1000wrms. My speakers are running off of a P400.4 which im bridging to give 200w x 2 @ 4ohms to a set of Crystal SSCS6's. Im running 1/0 guage back to the trunk, then running that to a 3 way distro from Knu...from the distro i will be running wire to the amps.
http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-23
I will be running 4 guage to the p400.4 which will have to be cut down at the end to fit the amp. I was also planning on runnin 1/0 guage to the P1000.1 but with the dimensions of my trunk and where the amps will be mounted, it is gonna be really hard to wire the amp with 1/0 guage. The wire is so unflexible that it makes running it to the amp really difficult.
Will it be sufice to run 4 guage to the p1000.1 or is 1000wrms pushing it for 4 guage? Would 1/0 guage be optimal in this condition, or will it not make much of a difference for me to notice and i should just run 4 guage?
Thanks...
Klep
Thanks...
Klep
