Processor Help
I myself am trying to go the processor route. I'm looking into the 9860+h701 combo, since i'm an alpine fan, too //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif . untill read this thread, i didn't know that the 9860 could control the h701. Thanks for the thread brandon //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif ...Ive been told that its a royal pain in the *** to control it with the 9860... Since im already running active, im not to sure what benefits i would get by adding it. That is why i asked about the Audiocontrol DQS. Its 24 bit digital signal processor with a 31 band eq for each channel. I want any and all input...so keep it coming
dammit, that's not what i wanted to hear... //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
well... the reason why i wanted to get the 9860 is for the dvd feature. With all your choices, i dont' think you can go wrong with any of them. just put the specs side-by-side and compare to see which will fit you better and be more convenient.
dammit, that's not what i wanted to hear... //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gifwell... the reason why i wanted to get the 9860 is for the dvd feature. With all your choices, i dont' think you can go wrong with any of them. just put the specs side-by-side and compare to see which will fit you better and be more convenient.
Well the cheapest and most convenient is the audio control DQS. I just wouldnt be able to run a digital signal to it. The PXA-h700 i hear unless u run a digital signal gets ground noise and is the second the most expensive..Then the Pioneer P9 combo has pretty much everything known to man on it and is the most expensive. So i dont no..I just feel like i cant make up my mind..//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
i'm in the same boat. i'm thinking about getting a dqx for my system.
dalucifer
Not Minion Approved
dalucifer
Los Angeles
iceteebone
