Pro Installer Help!!! LOC Problem?
highhpsupra
I think my preouts on my HU are blown since i dont get any voltage reading from either the front or rear preouts (Pioneer 4600MP).
So I thought i would use an LOC as a temp solutuon until i get a new deck.
I wired the LOC by tapping into the rear speakers. Took out my DMM and tested the voltage, it showed 0.2-1 volts at 1/2 volume from both left and right rca outputs.
I wired up a RF 200.2 to my IDQ, the amp powerd up fine, but no output.
I tested the power wire and it shows 12volts with the car off (no probs here)
I tested the REM and it showed voltage and the amp powered on (so no probs here either)
Ground i believe is good too since its bolted to the chasis and paint scraped
I dont know what else to check or what the problem could be? any ideas?
ALSO, the LOC is adjustable and i messed around with that setting and still nothing.
bad amp? (bought it brand new from bestbuy today)
any help is GREATLY appreciated.
highhpsupra
highhpsupra
Toronto, ON
highhpsupra
