Sold priemer prs amps
bdubs767
The amps are BNIB and I am selling all these items for a firend whos a car audio dealer just trying to clear out the old stock....
Preimer PRS 320 $210 x2
Priemer PRs 220 $190
Priemer PRs 720 $240
PG ti elite 6m $100
Are those the PG's that are based on or actually are the Morel's? (the ones with an insane power handling)
they are were built by morel, and can handle some juice.
They retialed for somethign like $300 in their day
lookinf for any trades or just cash
mostly cash, but really dpends on what u got. PM me wiht what u have.
Also since the amps have never seen power only been displayed they will still be under warranty as they are coming directly from a dealer.
specs are here....
x220
http://www.pioneerelectronics.com/pna/v3/pg/product/details/0,,2076_310069937_32906,00.html
Specifications
* Continuous Power (20Hz-20kHz, 0.04% THD)
o 2 ch: (4 Ohm) 30Wx2
o 2 ch: (2 Ohm) 60Wx2
o 1 ch: (4 Ohm) 120Wx1
* Maximum Power (EIAJ)
o 2 ch: (4 Ohm) 75Wx2
o 1 ch: (4 Ohm) 225Wx1
* Frequency Response: 10Hz - 50kHz (0,-1dB)
* Total Harmonic Distortion:
* Signal-to-Noise Ratio: >100dB (IHF-A Weighted, at 1kHz)
* Dimensions: 10-3/8" x 2-1/2" x 9-1/2"
Features
* Bridgeable 1/2/3 Channel Capability
* PWM Regulated MOSFET Power Supply
* 2 Ohm (4 Ohm mono) Optimized MOSFET Output Section
* Balanced Isolator Input Circuit
* Oversized Gold-Plated Screw-Type Power/Ground Terminals
* Gold-Plated Screw-Type Speaker Terminals
* Gold-Plated RCA Inputs
* Gold-Plated RCA Outputs (Full Range)
* Hi-Volt Input Level Control (400mV-6.5V)
* Variable Crossover: 50-120Hz, -12dB/oct. (LPF/HPF)
* Variable Bass Boost (40-120Hz, 0 to +18dB)
* Premier Power Certification Sheet
* Premier Two-Year Warranty
x320
http://www.pioneerelectronics.com/pna/v3/pg/product/details/0,,2076_310069937_36992,00.html
Specifications
o 2 ch: (4 Ohm) 50Wx2
o 2 ch: (2 Ohm) 100Wx2
o 1 ch: (4 Ohm) 200Wx1
o 2 ch: (4 Ohm) 125Wx2
o 1 ch: (4 Ohm) 375Wx1
* Dimensions: 10-3/8" x 2-1/2" x 11-3/8"
Features
* Subsonic Filter (15Hz, -18dB/Oct.)
x720
http://www.pioneerelectronics.com/pna/v3/pg/product/details/0,,2076_310069937_34073,00.html
Specifications
o 2 ch: (4 Ohm) 100Wx2
o 2 ch: (2 Ohm) 200Wx2
o 1 ch: (4 Ohm) 400Wx1
o 2 ch: (4 Ohm) 250Wx2
o 1 ch: (4 Ohm) 750Wx1
* Signal-to-Noise Ratio: >105dB (IHF-A Weighted, at 1kHz)
* Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
Features
o yea gorgot to mention these amps are underated, as the birth sheet that comes with them has them all doing double their rated power. for instance The 720 was above 800 watts on the birth
bdubs767
bdubs767
Mass/ VA
bdubs767
