john9721
So after seeing the replies and reading around on the Boss R1100M amp that I was planning to use with my next sub I've decided to return it. The sub I'm using is a single Rockford Fosgate R2D4-10 10" sub (250 Watt RMS, 4 Ohm DVC). I am looking at the PP Sedona 270.1 (270 watts x 1 @ 2 Ohms, 170 watts x 1 @4 Ohms). Would this be a good amp? I'm wiring the sub to a 2 Ohm load so I would get the full 270 watts, but are the PP amps good, and will it put of the power advertised? Also, 2 other things; am I thinking right in the way I want to set it up, and is 8 gauge wiring enough? Thanks!
