Preamplifier woes
What's the model and specs on it? Why are you selling it? And How Old is it?
I might pick it up because I need another pre-amp at home...
BTW, what's with the Anti-Fi in you sub thing there....
It doesn't //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
My stuff is based on designs that came about decades before stereo came into existence, you think I'm running balanced inputs? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I read the thread this time. lol
You have a tube front end and tube amp and arn't satisfied with the noise from
the tube preamp. You should look into my suggestion, reduce the gain... call
the company up? Fish for a schematic? You can probably reverse engineer
the wiring and draw up a schematic, it can't be that hard. How much stuff
is inside the rogue?
Right now the solution is to migrate from a tube preamp to solid state?
If so, does the tube amp support higher voltage preouts? or can you
adjust the gain on that tube amp, even if you need to mod it.
Basically, that's what I'm getting at. A high voltage SS preout and reduce gain
tube amp will offer less audible noise. The balanced issue is a secondary issue
not applicable to your situation.
I had a problem with a SS amp where it was too noisy for my taste. A simple
mosfet design that when you placed your ear inches away from the tweeter,
you can hear audible hiss. The root cause is the circuit design, the quick fix is
to reduce the amp gain and feed this amplifier a higher voltage 'clean' input
to compensate. All it took was a opamp preamp circuit on the front end, simple.
This cured the amplifier problems, you could place your ear right on the tweeter
and hear no hiss.
Yoda: Help you I can. Yes, mmmm.
Yoda: You must unlearn what you have learned.
Yoda: No. Try not. Do... or do not. There is no try.
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I know this is hard, but check out this schematic, a common SS amp.
http://www.leonaudio.gr/images/4x50sch1.JPG
Text book design, 3 stage.
R6 and R8 ratio determine gain.
If you look closely, R8 connects to the output which makes it the feedback
resistor for the input stage. You can raise R6 in resistance to lower gain
or reduce R8 or any combination of the two. Common sense rule says
that increase R6 is ideal because decreasing R8 can drive transistor Q2 with
more current.
In other words, changing one resistor in a preamp or power amp
can allow you to opimize your noise and get better results.
Amplifier Mod Made Simple[tm] By John Basedow //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
http://fitness-made-simple.com/?source=adwords
http://www.soundstage.com/revequip/rogueaudio_metis.htm
Thought this was interesting. A review of the Rogue Metis, a close relative of the Rogue Model 66, except with 6SN7 tubes...
When I hooked up the Metis to my Art Audio amp and ReTHM speakers, it was a bit noisy, producing easily heard hiss and low-level hum. The combination of a fairly sensitive amp input (0.7V) and very sensitive speakers (102dB) makes a very good noise detector. My standard noise remedy is to insert Rothwell inline attenuators between the preamp and amp, which reduces the signal to the amp by 10dB. The signal that is reduced contains the noise, so when the preamp volume control is turned to the desired setting, you’re getting more signal and less noise. The Metis has oodles of gain, so the Rothwell attenuators worked well. There was still a very slight buzzing from the Metis, audible only near the speakers. Yes, I tried floating the ground, but that just added some hum. Other preamps in my collection (deHavilland Mercury 2, Audio Note M2 Phono, and Audio Research SP9 Mk III -- all more expensive units) don’t exhibit a similar noise problem.
Describes my problem to a T.
There's some comedy to this.
To explain.
An amplifier has gain, and it's fixed gain as shown on that schematic I linked
eariler.
But, amplifiers with gain knobs are not really gain adjustments, they are input attenuators to reduce the signal, gain remains fixed
in spite that the amplifier is labed as 'gain'. ... lol ... You probably know this already ...
By adding input attenuators you are essentially making a 'gain control' even
though it's not the real thing. This can help relieve the problem, but if you
want to solve the problem at the root level, you change the amplifier gain,
that feedback resistor I talked about. This method will give you the best
performance because a high gain amplifier with attenuated input is still
in 'high gain mode' which can amplify noise present, usually noise from the
amplifier itself can be annoying.
Well 96 is...wait, that's the reason I'm having this **** problem in the first place.
JimJ
Tangled Up in Blue
JimJ
Hillsborough, NC
Beat_Dominator
