Preamplifier woes
It's a different gain structure... Simple... You DON'T NEED HIGH VOLTAGE PRE-OUTS!!!
Correct, you don't need unless you have a problem that needs solving.
I can argue both sides of this argument. The way I look at this is. If I was given
the choice to choose 1V unbalanced preouts vs. 8V balanced preouts and the
other variables remain the same including cost, then take the higher voltage
balanced design because you have insurance. You have to analyze all the gear
in the chain to make sure it supports it.
I use proamps in the home so it makes more sense to choose XLR balanced
high voltage preout preamps. Using low voltage and unbalanced is not optimal.
Like I said, I don't know what the OP has for his system, but I would look into
high voltage balanced preouts if his gear can support it.
What is so hard to understand about Low-Drive = Efficiency = Clarity!!!
Makes no sense, explain.
Less voltage = less distortion
That is a design issue. You can make a 300v preout with low distortion. Many
quality opamps can do high voltage preouts as a standard feature with inaudible
distortion. It's the design engineers who dummy down the circuit so it only offers
1V to maintain that ancient home audio standard. lol ... ie, IIRC, the ancient 5532
opamp can do 9v rms output, a $1 opamp. If I was building a custom preamp
and amplifier, there is no reason I'm dumb down that opamp to 1v, I'd take
full advantage of it's abilities.
less voltage = less crosstalk
This is a design issue. Crosstalk is determined by many variables. You can design
a low crosstalk circuit with high voltage.
smaller components = faster components, faster components = more accurate ones.
I don't understand what you are saying here, explain.
Pro-audio uses XLR and Higher Voltages for a simple reason distance.
There are too more variables as to why do they this.
There is more to gain with balanced, high voltage preouts than low voltage
unbalanced. It's basic electronics. This doesn't imply that unbalanced, low
voltage will have problems, but there is less change of gremlins
manifesting with the other. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
FYI, I'm not picking on Rotel or Parasound, nor do I really pay attention to what you folks have
in possession. I just randomly chose those two products to illustrate my preference...
so.. don't take it personal... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I use proamps in the home so it makes more sense to choose XLR balancedhigh voltage preout preamps. Using low voltage and unbalanced is not optimal.
It doesn't //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
My stuff is based on designs that came about decades before stereo came into existence, you think I'm running balanced inputs? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
What's an opamp?
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I think mine fell out somewhere...
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
So Jim, you're sure this:
index.php
: is too ugly for you? I'm going to put it on the 'Bay tomorrow if you for sure have zero interest.
Will do Jim.
ballstothewall: balanced uses 3 conductors instead of 2. 2 pass the + signal but in opposite in phase to eachother, then the 3rd is the - . Balanced lines tend to be a bith higher in voltage as well.
Balanced lines have the advantage of rejecting RF noise better than single-ended interconnects (ie, RCA). RF in the signal, CAN have the effect of making hiss/noise/grit/grain worse. Having the amp deal with abnormally high frequency content/RF might cause it to go unstable, in some cases... many amp designs are NOT meant for that kind of bandwidth!
Of course, RF-stoppers (ie, the ferrite beads that snap onto interconnects and power cables) can help in a case like this, with RCA interconnects. But, there's only so much you can do, when the cable itself WANTS to act like an antenna (unlike a balanced cable, where RF basically CANCELS ITSELF OUT, inherently)...
Regards,
Gordon.
What's an opamp?
Oh nooooossssss.....
So Jim, you're sure this: http://bilder.minhembio.com/bild/index.php?pic_id=82942.jpg : is too ugly for you? I'm going to put it on the 'Bay tomorrow if you for sure have zero interest.
How much are you looking to pawn it off for?
And Thy, I'm busy right now, but as soon as I get unbusy I'll answer those questions for you //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
JimJ
Tangled Up in Blue
JimJ
Hillsborough, NC
Beat_Dominator
