PPI PC21400 amp
john_817
Hi. I have a PPI PC21400 amp. It's a 2 channel amp and I am hooking up 2 kicker L7's to it. The amps rated power is 350 WRMS x 2 @ 4ohm per channel, 700 WRMS x 2 @ 2ohm per channel, 1400 WRMS x 1 @ 4ohm bridged. Right now I have been going with the 4 ohm version of the L7. should I get the 2 ohm version of the L7 in order to use maximum power from the amp? or is the 4 ohm version fine. Right now I have 2 subs wired parallel in stereo. Is that getting me the 700 watts per channel? or If i wanted the 700 watts i should get the 2ohm L7's. or the other option is to keep my 4 ohm and bridge them? Please tell me the best way to set it up. Thanks.
john_817
john_817
DEEEFFDUB
john_817
michigan born
    May 14, 2026
michigan born
    May 14, 2026
