ppi pc1400 $value$ question
req
am a mod.
so i got the manual for it from some ebay acution, it says this;
Power Bandwidth 4.5 Hz - 100 kHz
Total Harmonic Distortion 0.02 %
Input Topology Balanced Differential
Input Sensitivity 120 mv - 12 volts RMS
Input Impedance 10 k Ohms
Load Impedance 2 - 8 Ohms
Supply Voltage 11 - 15 volts
Damping Factor >500
Slew Rate >50 V/mS
QBASSâ„¢ Up To +12dB Boost @ 40Hz
Idle Current .7 Amps
Crossover Hp/Lp 12dB/Octave Linkwitz-Riley
Crossover Frequency Variable 20-5kHz
Continuous Output Power
PC1400
200 WRMS x 1 @ 4 ohms
400 WRMS x 1 @ 2 ohms
so ~400rms, and prolly underrated at that.
ther is an ebay auction for $175 for this amp. but mine is the chrome one (a few scratches- can most likely be buffed out of the chrome too, but works perfectly)
what do you think its worth. i realy have no idea? heres a picture;
req
am a mod.
req
Syracuse, NY
req
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
