PPI A600 / Or Sub Problem
jace314
CT
Im new here, so Im not sure if Im posting in the correct place. Anywho...
I have an old PPI A600 amp, and 2 new infinity dual4 ohm voice coil subs that I just bought.
I ran the wiring for the subs as it said on the rockford wiring wizard for the 2 dual 4 ohm setup. So I have the subs paired up, and the negitve from the right sub, and the positve from the left connected to the Left +, and the Right - bridged. The gain is not up that far maybe half if that.
I seem to be getting a distortion through the subs. Is it possible that the subs cant handle the bridge? Or is the amp going bad?
I cant find any wiring diagram that shows how to setup the dual voice coils to both channels on the amp and NOT using bridge.
Any help would be great!
Thanks
The A600 needs to be bridged a certian way... Try the other way.
I have one and I don't know what it is... Exactly. I could walk outside and see what it is, but the vehicle and owner are out boozing it up.
Problem solved! I decided to re-run some new 4 g power, and ground cables. Much cleaner and shit load more power!! The bridging is L+, and R- on the old Art PPI A600.
Thanks
jace314
jace314
CT
jace314
michigan born
    May 14, 2026
michigan born
    May 14, 2026
