Powering DLS comps & coaxial
So, i wouldnt blow them or distort them with too much power? Is that amount of overhead a good thing?
Solution:
Set the gain so at maximum non-clipping HU output the speakers are not displaying signs of stress. I suggest using pure tones at the lower end of their range to provide a "worst case" scenario for this setup procedure. Say they are crossed at 50 Hz use a tone at like 55 Hz or so. Do not use volume higher than this level on the HU and you will never damage the speakers.
Solution:
So, basically its safe to say just dont play my music 75% of max volume
Are there any other options instead of the JL 450/4, open to suggestions with comparable quality and performance. Wanted to see if there were cheaper options than the JL amp.
As you will soon learn young Jedi, power is a very good thing to have:yumyum: And that 450/4 will serve you well!!
I know that that JL 450/4 will be a good choice, but do you guys think that two 2ch amps will work as good if not better than the JL. I was looking at the Arc Audio series either KAR or XXK.
A pair of those certainly wouldnt be "cheaper" than the 450/4
Well i could get both Arc KAR (400.2, 200.2) for $450 total, and i cant seem to find the JL 450/4 for less than that. I havent used either brand but it seems to me Arc amps are better in quality and sound, i think. Any input???
So back to the question at hand, 2 2ch arc audio amps (KAR series) or JL 450/4. Would there be any sound difference or is one better than the other? Open to other options.
azngotskills
azngotskills
Dallas, TX
azngotskills
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
