but seriously though...
I guess you could say I'm between installs right now. I was pretty happy with my Alpine SPX F17M set being fed by a JL 300/2, but then I needed some money and I had to put it all on
ebay...the EQ, the Cap, Subs, and sub amps. So, right now, I just have a pair of Infinity Reference coaxials up front with some boston acoustics in the rear with a clarion 4 channel on duty. The Infinity Refs are rated at 60 RMS. The amp is rated at 80 watts/channel. I have the gains up about halfway with the hi-pass set at 55hz. These speakers just couldn't sound better, given their limitations as low-end coaxials. So, what does that tell you? It tells you that specs (like those that are listed on the box) really don't amount to jack squat in the overall scheme of things. Don't look at your speakers' 100 watt rating, then at your amps 150/channel rating and say "I've got too much power". Infinity aren't the greatest speakers out there, but they certainly aren't crap. It would be pretty **** hard to do major damage with the amp that you have. Moreover, that 150 watts is probably a "dynamic" rating. This means it's the power the amp produces when getting the full 14.4 volts from your battery. On average, unless you beefed up your electrical system, the voltage going to your amp will be around 12.5V-13.5V. This means your amp is not producing 150 watts/ channel. Furthermore, The volume knob is always what ultimately controls how much power your speaks are getting. Unless you have it cranked so loud that deafness is working its way through your eardrums, 150 watts -again- is nowhere near what is coursing through speaker wires. You paid $$$ for some nice speakers. That doesn't mean you need to treat them like they're priceless artifacts. Set your amp loose on them. That's what they're made for. We're not talking Lanzar or Kencrap here.
