Powerbass pbx T/S parameters
Does anyone have the t/s parameters for the XS12Dv2 12in sub. including the mounting depth and v.c. diameter
thanks patrick
Fs: 31Hz
Qms: 5.6
Qes: .57
Qts: .52
Vas (liters): 48.8
Nominal Imp (ohms): 2ohm + 2ohm
SPL 1w/1m (dB): 88.4
SPL (2.83v/1m): 94.2
X-Max (mm) one way: 13
Pe-RMS: 800w
PE-Max: 1600w
Freq. Response: 20Hz - 500Hz
cut out diameter: 11.1"
mounting depth: 6.9"
voice coil: 3"
Thank You. I was just trying to compare them to some Soundstream tarantula t-4 12 subs. I have not heard much about either one but they are both reasonally priced around $200ea. and model well in the box I want to build.
XS10DV.2 XS12DV.2 XS15DV.2 XS12D1V.2 XS15D1V.2
FS 35 31 29 35 32
QMS 4.5 5.6 3.7 5.6 3.7
QES .534 .57 .38 .58 .41
QTS .477 .52 .35 .53 .37
VAS/ LITERS 21.16 48.8 89.6 48.8 89.6
OHMS 2+2 2+2 2+2 1+1 1+1
SPL 84.4 88.4 91.5 88.8 91.7
XMAX 13mm 13mm 13mm 13mm 13mm
PE 800 800 1000 800 1000
*Sorry if its messy..had to copy and paste from different formatting. But these are direct from Powerbass.
Thanks tplaya07. Can you get more #'s for subs like the PB-C1512DS or the PB-B1564v.2.
Do you have any prices for these or box recomendations too?
BTW, other than the PBX, which of the other 15's is more sq oriented? I thought they labeled some of their subs as "sq"....
Yeah, the Evolution (ES) series is the SQ ones your looking for. They have been doing very well and have set 8 new records.
...more parameters on the way...since everyone is asking...
Thanks for the info guys. I tried to get my pdf deal working, but it's still messed up //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif So I still can't see most of the info from their site //content.invisioncic.com/y282845/emoticons/censored.gif.f9ad8e7c6db58c5530c5a0a20a3b5baf.gif
tplaya07, check your pm's
fforward27
fforward27
VENTURA, CA
Bobyota
    Jun 20, 2026
    Jun 20, 2026
