Powerbass 3000 amp!
ebay link to my auction
Powerbass-XA3000D-mono-amp-3000-rms-1-ohm_W0QQitemZ9738642466QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Sweet this isn't the classified section.
That XA3000D isn't worth $400, they can be had BRAND NEW with warranty for less than that (if you know what you're doing), they won't be all scratched up, and you don't have to worry about some guy who doesn't know the differance between 4g and 1/0 owning it.
dude, you need to get off your highhorse, ok, If you look at my last 4 or 5 previous posts you will see that I was having problems uploading a picture, deal with it. Actually brand new Realm of excursion has them for about 900.00 so I would say half price shipped is a pretty good deal. Also uless you buy used you will not be able to find this kind of power this cheap thanks.
hey check this out straight from powerbass website: eat crow dude
PowerBass Xtreme Class D Amplifier Features:
1000 watts x 1 @ 3 ohms
2000 watts x 1 @ 2 ohms
3000 watts x 1 @ 1 ohm
Features:
Remote Bass Control (Included)
Wired dash mounted remote allows you to fine tune the amps special BASS EQ circuitry. Variable from 0~18dB.
Strap Two Amps Together for Double Power Output
Allows two of the same model amplifier to be combined in a Master/Slave configuration to function as one for increased power.
Oversized Power and Ground Inputs
Heavy duty 4-Guage CNC machined high efficiency Power and Ground Inputs for maximum power transfer.
24 dB/Octave Electronic Crossover
Variable LPF (Low Pass Frequency) from 20Hz~1.5KHz plus a separate variable Sub Sonic filter for maximum system flexibilty.
Self-diagnostic Protection Circuitry
4-way protection circuitry guards against Short Circuit/Thermal Overheating/Impedance Overload and DC Output
Input Sensitivity: 200mV ~ 6V
THD:
10.51" x 2.56" x 20.87"
idiots pure idiots,,,,, i did not say it was mint, no where did i say that, i think i even say it has some scratches, also, the amp holds 2/0 ga wire, please read the complete post before responding to anything on any of my post
ZeroGuage
ZeroGuage
Sandusky, ohio
DRCKISS
Mike Mccabe
