Power Wire?
BleuGT
UT
I am trying to determine what size power wire I will need to run. The power wire will be roughly 12ft +/- 1ft. I was set on using 4awg but after doing some research, i am now contemplating 2awg. My system will consist of:
Planet Audio tt850d - 600w @ 2 ohm powering RE SE10 (600w rms)
Audison SRX 2s - 2x200w @ 4ohm powering Hertz HSK 165 (125w rms)
Do you guys think that 4awg will be sufficient? The only thing that may change is i might upgrade the Planet Audio to an Audison SRX 1D (850x1@2ohm).
Lets hear some opinions.
Thank!
if you just put in as big as you can afford now it will save you when you get addicted and start going louder later. I always think I'm dun and don't need more then get bored and add more. Its like crack you wont stop. The 2 gauge can handle that current but why not just go 1/0 it looks bad *** and most terminals and fuse holders fit it nice. If you do it now you just won't have to do it later.
Ok so i think you've talked me into into the 1/0. I cant find the 2awg hardly anywhere and it makes since in case i do upgrade.
But i have to ask.....what type of fuse should i go with? Knukonceptz offers 60a, 80a, 100a, 120a, 150, 200 & 250. I have no idea which to get?? Any help?
-Tyson
BleuGT
BleuGT
UT
helotaxi
BP1Fanatic
BP1Fanatic
