power Wire
there's no circuit at the fuse box that can withstand much extra current b4 fuses start to blow. It will work for a low current accessory wire - such as a switched source for an HU, but something even as small as an HU amp can easily blow those fuses.
Not to mention, if you wire something too big to the fuse panel then your car could catch fire. I salvage parts out of old wrecked cars, most of them only had like 12 and sometimes even 14 guage wire to the fuse panel.
I can't see that happening unless you replace one of the fuses with something larger than original, but anything's possible I guess.
Well righ tnow it is hooked up to that point and when my amp was hooked up maybe for about a month or more it didnt blow anything and it powered my amp so i just wanted to make sure i was fing anything u. I read in some thread saying it must be hooked straight to th ebattery.
playa1
playa1
Palm springs,Florida
playa1
michigan born
    May 14, 2026
michigan born
    May 14, 2026
