Power Wire size compared to ground question
zedsdead
if anyone would like to shed some light on this, all is appreciated. okay i am running a 4 channel amp and a mono amp. from the battery i am running 1/0 power wire into a distribution block which is two outputs of 4 gauge. each 4 gauge going into each amp respectively.
i will be running two separate grounds for each amp.
question, should i run 4 gauge grounds? i have been told in the past that its best to match the gauge wire of the power & ground. But seeing that what is actually making contact with the amps will be 4 gauge power wire, should i match that with 4 gauge ground? or use 1/0 as grounds?
another idea that was floating in my mind was getting a ground distribution block and run the two 4 gauge grounds from the amp into the block and the output would be one 1/0 ground. not sure if its a good idea to ground two amps with 1 ground though.
some input would be greatly appreciated thanks
-Jesse
You would be better off running two 6in 4 gauge grounds than running a 0 gauge distribution into two 6in grounds. But I you only have 4 gauge going into the amp, than you only need 4 gauge coming out. Basically if I understand this right, even if you ran 0 gauge into the amp with 4 gauge grounds, you would have the same power as running 4 gauge power to the amp and 4 gauge grounds.
thanks for the feedback guys. i will just run a ground distribution block with 1/0 grounding to the chassis and the other 4 gauge going to the amps. thanks for the input.
the wallet friendly way would be running two 4 gauge grounds.
zedsdead
zedsdead
toronto
zedsdead
vegang
vegang
