power supply/battery wiring help
Can I ground my amps directly to my secondary battery? I feel like that would be a cleaner and more stable ground than a chassis ground...
xs power d5100r as my underhood, d6500 as my secondary, is that a decent combination for running a 4000 watt rms setup? do i need to fuse the power cable running between my main underhood battery and my secondary?
Fuse the 2ndary like the primary about 12" from the terminal.
Wouldn't the current flow between the two batteries exceed 250amp? My sub amp alone requires a 300 amp fuse, and yes I would only be doing 0 gauge
Can I run my three amps straight off the battery terminals or should I get a distribution block to the three amps? Would a distribution block have a "bottle neck" effect on my amps holding back the power they need?
imloudek
imloudek
ny/nj
imloudek
