Power Problems, PLEASE HELP :(
AndrewFlanders
When I was hooking my amp up, I had everything in working order. Then I went to mount my amp and everything, including my deck shut down. The ground wire to the amp may have become disconnected, but in any case, even without the amp's 12v remote turn on wire connected I cannot get my head unit to power on. What are some possible solutions?
Thanks.
Andrew
I'm not sure if i have voltage at the deck. When the face is off, the red security light blinks which to me would indicate that there is some power being fed to the deck. On the other hand even with all amp wires disconnected, the deck will not power up.
Use the test light to check, if you don't have one, buy one becuase you shouldn't go any installs without one really. A test light (or a DMM) is a very essential troubleshooting tool.
Or you can lick the wire //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
AndrewFlanders
AndrewFlanders
Dallas, TX
ANeonRider
michigan born
    May 14, 2026
michigan born
    May 14, 2026
