why would you loose power handling by tuning lower? that doesn't make sense to me.how much power handling do you loose by lowering tuning frequency?
a sub should move less as long as it's not playing information below tuning. i don't see how tuning lower will increase excursion. lower frequencies do require more excursion, but cone movement will be at a minimum at and around the tuning frequency of the box.may be a misunderstanding on my part...
when i had my rsd's in a box tuned for 45hz, the excursion of the speakers were very small at lower frequencies, and now that I am at 24hz, the excursion is amazing....
more power=more excursion, so if people are talking about running rsd's on 800+ watts, and i am running ~240 now, and the excursion is what it is, then when i add more power I will have possibility of mechanical failure![]()
the 24hz is such a flat response it is rediculous...no audible peaks, and the lows are amazing..calculated and proven to my ear...a sub should move less as long as it's not playing information below tuning. i don't see how tuning lower will increase excursion. lower frequencies do require more excursion, but cone movement will be at a minimum at and around the tuning frequency of the box.
now, making the box bigger will allow the sub to move farther off of less power, thus lowering power handling. i think the way to go is a small box tuned low.
oh and 24hz tuning in a car is crazy low. hell even 30hz is kinda low for a car.
well, doubling the power doesn't double excursion. just remember that. i can't remember how much power it takes to double the excursion of the top of my head though. you should be fine. i run a 600 watt rated sub at 600 watts tuned to 30 hz and don't have any problems, i don't think you will either.the 24hz is such a flat response it is rediculous...no audible peaks, and the lows are amazing..calculated and proven to my ear...I was just curious that since i am getting such excursion already, would adding 500 watts per speaker bring potential for mechanical failure due to over excursion
yea...i know doubling power won't double excursion, i was trying to make sure that when i added the power that i want to feed the rsd's that i wouldn't cause an issue...and from your response, it seems i will be fine..well, doubling the power doesn't double excursion. just remember that. i can't remember how much power it takes to double the excursion of the top of my head though. you should be fine. i run a 600 watt rated sub at 600 watts tuned to 30 hz and don't have any problems, i don't think you will either.
and i hear ya on the flat response. thats how i made my box.
yea but the question is how much is it really moving. "a lot" is kinda vague. also it depends on the music your playing, although not a lot of music gets down strong into the mid 20's.if your sub is movin a lot with 240 watts, why do you need more? you're just going to push it past mechanical limits
