power handing question
i am currently upgrading my subs from 2 12inch kicker comps with a 800 watt ssl edge to 2-12 inch 1500 watt rms PA Mofo 124x dvc 4 ohm ran off a PA gothic gt 6000 watt max (haha right?) mono block (3700 watts@1 ohm) will be ran parallel to 1 ohm
i also run a 400 watt 4 channel mtx amp for my door speakers.
i drive a 2001 yukon slt pretty sure i have a 145a alt
i plan on doing the big 3, putting a second battery in the back (4000 watts) ran parallel with an isolator and a capacitor.. all 1/0 gauge.
my questions is should this be enough to run my system? or just not on full volume all the time
now i know i should upgrade my alternator and i do plan on doing so down the road. will be adding a second alternator for a dual alt set up. (so i can get bigger down the road and not have to redo it)
It is, but the equipment is still very over-rated. Will that amp do 3700@1 ohm clean? No way in hell. Maybe somewhere close to 3k on a clipped dynamic burst on 18v.
Don't waste your money on that capacitor.
See what voltage drop is, then get stuff. You probably will need at least a good AGM under the hood
I almost pulled the trigger on pgeojix gold elite 2s and with an elite 1 set up.. Just not trying to spend that.. I've listened to the pa sub's.. I want thump, its what they do.
So what until I get everything installed before I upgrade? That way I can see how it handles?
if you want thump and you think power acoustik can thump, just wait till you see real subs. Also we had a member test that sub on real 750 watts of power and that sh*t burned up. Just know with lower tier companies, they lie about their power by far. Same thing with their amps. You take away a 0 at the end and you will get the proper output their amp does. You may think you are getting a deal but you are getting screwd pretty hard
A big part of your thump is how well your box is designed.
I wasn't asking for ur thoughts on a equipment, just set up. If this works for me, and makes me happy.. Why do you care what I run?
Just trying to save you some money and disappointment, but by all means, do what you like. Prove to the world once and for all that you can polish a turd.
I understand that, but if they only push 1000 watts a price and I paid 465 for the system, I will call that a win. When I get everything set up, I will test watts and such and see where it truly stands
It's not a win. But like said, do what makes you happy.
Keep supporting brands that need to go out of business.
You just have to do some research, spend a few days trolling YouTube, whatever, and see what the good brands are.
Then, you look for good deals. I waited for months with no system for the right deal, slipped and fell into over $3k worth of brand new Digital Designs gear , paid about 10% of that cost. Granted, im having issues with my current build, but still. I spent less on my system and its all top of the line stuff.
I have a hard time saying things nicely so ill just say I agree with what everyone else has said. But whatever tickles yo pickle
MontanaDave
MontanaDave
billings, mt
BP1Fanatic
BP1Fanatic
