Power distro
goodstuff
LOL
So,
I'm going to run two amps and an eq, a 7" monitor,sarotech media player and dedicated connection to the clarion drz dc power supply. In the past I had run a two fuse anl style fuse block for the amps and just piggy backed the wire for the drz off that. Now that I am adding the monitor, eq's and media player I can't seem to find an all in one fuse block solution for what I want. 1 1/0 in, 2 4 gauge out + at least 2 8 gauge out or what ever will work for the accessories. I've seached quite a bit, anl fuse style is what I am running now and I'd like to keep that if possible since I have spares at the correct ratings for my wires/amps. I want one run of 1/0 from the battery to the trunk but I think at this point I could live with 1 1/0 and 1 8 gauge, just trying to keep the number of wires that run under the carpet to a minimum. I'll post up a diagram of everything I'll be running shortly.
wouldnt you still need to have an inline for those 4/8/2 guage wires leaving the buss bar to the amps though cuz of the wire size change from the 0 gauge?? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Ya IMO that would be easier to work with.
So this is what I've got so far:
Comments and Suggestions welcome.
I always fuse to the wire not to whats at the end especially when whatever is at the end has it own fuses; amps and power converters. 0 Gauge wire 300amp fuse and 4 gauge wire 130 amp fuse. Never ever had any problems. also gives u room to upgrade.
I'd rather fuse lower and be safer. I realized the wire could handle a bigger fuse but when I'm drawing less then 125 amps why should I use a 200 amp fuse? My amps don't have fuses, and neither does the eq, media player or monitor. I can always just put in a higher fuse later on if need be.
goodstuff
LOL
goodstuff
Northeast
goodstuff
