Power Cap ?
Mayshno
Kuwait
if i wanted to connect the subs i have with the Amp do i have to buy a 1 farad power cap?
my battery capacity is 46 Ah , Alternator output 105 A . whatever that means //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
will be runing amp to about 3/4 gain .
thanks //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
caps are worthless.
you shouldnt have to worry about anything because looks like what you have wont put really any stress on your electrical system.
only situation in which they might be usefull is if the electrical system is up to par....then it would jus help to smooth out any voltage drops.....but its not really needed if the charging system is good
Originally posted by Grand AMature stop saying caps are worthless...your retarded.
*you're //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
With a sufficient electrical system, caps will have absolutely no use.
Originally posted by snova031 *you're //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
word
btw, i learned that AFTER i bought myself a cap:(
I disagree, because no matter how big your alternator, or how many batteries you have, they cannot deliver the power as quickly as a cap. Think about how caps are used outside of car audio, one of the simplist uses is in camera's. Your batteres take a bit to charge up the cap, and the cap instantly discharges energy to make your flash. The key word being instantly, if batteries could do that there would be no need for caps anywhere in the world, virtually all elctronics have caps on them, because they do just that, release a little bit of energy instantly when it is needed. I dont debate that caps are almost always misused, but they do have their purposes in car audio.
Originally posted by evo2k3 I disagree, because no matter how big your alternator, or how many batteries you have, they cannot deliver the power as quickly as a cap. Think about how caps are used outside of car audio, one of the simplist uses is in camera's. Your batteres take a bit to charge up the cap, and the cap instantly discharges energy to make your flash. The key word being instantly, if batteries could do that there would be no need for caps anywhere in the world, virtually all elctronics have caps on them, because they do just that, release a little bit of energy instantly when it is needed. I dont debate that caps are almost always misused, but they do have their purposes in car audio.
interesting.....the way i see it, if u feel like paying the extra money it wouldnt hurt but isnt needed.
Originally posted by Mayshno if i wanted to connect the subs i have with the Amp do i have to buy a 1 farad power cap?
why are you planning to run the gain at 3/4?
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
455
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
692
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
507
Mayshno
Mayshno
Kuwait
dave_3148
    May 31, 2024
    May 24, 2024
