Power & Sealed Box Size. Confused. (Best Brahma12 Config)
BasketBaller
I've looked everywhere to learn what the best configuration is for a 12" Brahma is and I found this.
http://www.acousticconcepts.com.au/adire/MOVIES/BrahmaPowerHandling.pdf
Is it better to have the brahma getting 1300 watts in a .62cu ft3 box or 500 watts in a 2.10 box? I figure that in the smaller box, it won't have as good a lowend. Is this true?
Will is get louder with more watts in a smaller box or less watts in bigger box?
What is the optimum (BEST) sealed configuration possible for a 12" Brahma? I am looking for SQL, leaning on the SQ side. To be exact...tell me the ft^3 before displacement.
ps. How much volume does a 12" Brahma displace? (if anyone knows)
Link doesn't work.
The smaller the box, the better mechanical power handling the woofer is capable of. No box will raise or lower the thermal power handling of a sub though.
Yes, a smaller sealed enclosure will reduce low end output, and have a peak in frequency response closer to the mid/upper range.
I generally like to go oversized slightly with a sealed enclosure to try and reduce the peak as well as get a little more low end response.
BasketBaller
BasketBaller
Massachusetts
BasketBaller
