power acoustik
They are kinda cheap. Maybe just right under Profile and over Pyramid.
I like profile man. As long as you look at the RMS they put out cheap, clean power and the amps are extremely reliable.
The durability of profile is nothing like the durability of pyramid or power acoustik. Profile is mucm much more reliable.
That said. Power Acoustik has a few lines that do decent power, but not the amount they are advertised as. The durability of their product seems to be hit and miss. I have had a chance to play with a few power acoustiks and I found them to be hit in miss in the reliability department, and ok for some budget power as long as you dont get sucked into the peak ratings. Their most notable models are the PA3000BD (1800/2400 as well)
I think they're ok too. I meant they are cheap in price. It's good budget stuff and yes, I hear that they do put out rated power. I'd run it.
All depends on the model. You have one in mind you can show us?
all the mono blocks in the same series as the a2400db and the a3000db are solid, rated, built like tanks, and outperform simular more exspensive amps. i've played with these amps many-o-times and they've impressed the hell out of me. especially the a3000db.
the rest of the entire power acoustik brand rather it be subs, amps, whatever......ussually garbage.
What about the BAMF line? would that be a decent amp?
I need about 2000wrms @ 1ohm. I plan on buying the BAMF-4000D or the 5500D to compensate for the over-rating.
What about the BAMF line? would that be a decent amp?I need about 2000wrms @ 1ohm. I plan on buying the BAMF-4000D or the 5500D to compensate for the over-rating.
If your lookin for a cheap 2000x1ohm RMS amp I LUB my soundstream TRXD2000, Under $400 on the bay
Be carefull of the 5500D, I think it has screw type power terminals, I have trouble thinking it turns 14.4V into 2000 (let alone the rated 3200) through a screw clamp. I could be wrong though, I have been in the past.
02xblazer
02xblazer
iowa
n2audio
AJ (ACE)
    Jun 28, 2026
