power acoustik fubars
Please dont buy these. They might get loud but the sound quality and overall sound quality ***** on them. I had one(well two) sealed and ported and it was just a big pig and my 600watt mono was able to blow it without any problems.
Pick up something from the RE Audio line. You amp would not be enough to power two 12 woofers btw. You can get two RE SE12 woofer(amazing btw) for $220-$240.
You are going to have to change amps if you plan on running two of them though.
Kevin
Kevin
I agree you should get something from RE audio here is a RE SE12D4 12" 600W RMS Dual 4 Ohm for $99....so you can have two for $200, plus the shipping and they are by far better subs
http://www.rickiesdiscountelectronics.com/re-audio-se12d4-12-600w-rms-dual-4-ohm-voice-coil-se-series-sub-16508.html
I used to run a pair of the 10" FX series subs and i loved them...
Ran them on suggested power and never had a single issue with them. Even ran them on my Autotek MM4000.1D down to a 1ohm load and they handled that power just fine too. box was something like 3 cubes net @ 40hz
Do they compare to my HDC or XXX or anything like that, HELL NO but they where better than any pioneer, sony, kenwood and JL subs i ran back then (yeah... i know...) If it comes down to needing something cheap quick, i will for sure buy them again.
There are quite a few options for you to look at, I mean no offense but you are obviously not too concerned with the quality and craftsmanship or anything so look around, you can find better...
I have heard these in a best buy "off the shelf" DUAL brand bandpass and they slammed pretty good...
http://cgi.ebay.com/12-INCH-2000-WATT-PAIR-VOLFENHAG-12-SUBWOOFERS-AMP-SUB_W0QQitemZ110310273226QQcmdZViewItemQQptZCar_Subwoofers_Enclosures?hash=item110310273226&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
DIRT CHEAP Audiobling...
http://cgi.ebay.com/2-AUDIOBAHN-AW121T-12-4-ohms-CAR-SUBWOOFERS-SUBS-PAIR_W0QQitemZ360106048155QQcmdZViewItemQQptZCar_Subwoofers_Enclosures?hash=item360106048155&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
RE
http://cgi.ebay.com/2-RE-AUDIO-RE12-12-SUB-WOOFERS-CAR-SUBS-350W-RMS-pair_W0QQitemZ400012725586QQcmdZViewItemQQptZCar_Subwoofers_Enclosures?hash=item400012725586&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
Hifonics
http://cgi.ebay.com/2-HIFONICS-HFi12D4-12-1200W-SUBWOOFERS-SUBS-NEW-PAIR_W0QQitemZ300274828100QQcmdZViewItemQQptZCar_Subwoofers_Enclosures?hash=item300274828100&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
MTX
http://cgi.ebay.com/New-Pair-MTX-Thunder-600W-12-DVC-Subs-Car-Subwoofers_W0QQitemZ200275328578QQcmdZViewItemQQptZCar_Subwoofers_Enclosures?hash=item200275328578&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
Kicker
http://cgi.ebay.com/2-KICKER-05CVR124-CompVR-12-Car-Subwoofers-PAIR-CVR12_W0QQitemZ290275225981QQcmdZViewItemQQptZCar_Subwoofers_Enclosures?hash=item290275225981&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A15%7C39%3A1%7C240%3A1318
ALSO: if you make up your mind, head over to google, click on shopping and type it in. You can usualy find stuff cheaper than ebay...
Cable plugged in all the way? I know I had one and it didnt plug in fully unless you jammed it in pretty hard. Also, I suggest DS18 Bass Knob with...
I would consider a different brand. Whats your budget?
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
498
aj3000
aj3000
tacoma, washington
aj3000
