power acoustik amps any good???
search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search
They're fantastic.
so then when this amp says that it will put out 1800 wrms at a 1ohm load it will actaully put out almost 900 watts rms to each sub. it is going to be hooked up to 2 subs just so everyone knows.
alright thank you all for the replies. I plan on running my 2 12" kicker SB L7's off of this amo unless there is another amp that you can suggest for close the the same price and power??? that would be better. thank you all once again
when you say set good does that mean I should keep the gains on the low side?? what is your gain set at??
The gain will vary from amp to amp, car to car.
You need to set it properly yourself, not ask others where they set theirs, same amp or not.
Read the Gain Setting Tutorial at the top of this forum, should do you some good.
yamaman
yamaman
Shaunavon, SK
theCybe
BP1Fanatic
    Jun 2, 2026
BP1Fanatic
    Jun 2, 2026
