Possible overheated amp question
john3387
well, i think this great texas weather may have ****ed up my amp. a few days ago, i poped a fuse, so i fixed it and go check the wires to may sure that wasnt the problem. i notice that the power wire was melted black and really ****ed up. i fix the wire, and now my amp will not stay on for more than a second. i just get one little push to the sub and it blows. its been a really hot summer here averaging about 100 or so the last few weeks. ived check the ground and power lines for any little thing wrong with them, and i can not find anything wrong with them, so is there any way to fix an amp that has overed heated due to extreme heat, or am i ****ed? thanks for any help!
also i have not been pushing it very hard either, i got the gain down nearly half, so it hasnt been over used, just a little fyi so you dont think im an idoit pushing it that hard when its already so ****ing hot outside
Did you run the power wire through the firewall with a grommet?
The fact that the wire got hot enough to not only blow a fuse, but melt the wire tells me you've got a short somewhere...
The position of the gain really has nothing to do by itself with how hard the sub is being driven.
john3387
john3387
Houston, TX
john3387
