Portsize-Portlenght
I calculated --
a box tuned at 26hz, with 72sq inch of port, with 4cu.ft net, must have port length of 7inch, is that correct?
I calculated --
That would be closer to being right if you were going for 46 hz //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
It can be sub dependant, but not usually.. The only thing i can see is port noise.. And with a port as big as that i doubt you'll see any.. Seems like a small box for that sub
a bigger port port will need to be longer than a smaller port to have the same tuning.
I think he's got that but hes just asking if there is say a difference from haveing a port thats 2x14 tuned to 26 hz, as opposed as a port thats 4x14 tuned to 26 hz.. Other than the port length getting longer .. Is there any advantage to having more port area.. Right?
ya thats wut i meant! is there a difference in the sound? is it louder? more peaky?
SQBubble
SQBubble
MTL
tRiGgEr
