porting a box
substance
houston
how would i go about porting a box? its not just cutting a rectangular hole in the box is it? you actually have to run a port into the box right? How would someone go about doing this to a box thats already built? like what material would be used, and how do you know what size to make it?
Originally posted by substance how would i go about porting a box? its not just cutting a rectangular hole in the box is it? you actually have to run a port into the box right? How would someone go about doing this to a box thats already built? like what material would be used, and how do you know what size to make it?
find the net box volume, decide on a tunning frequency and a port area, if your doing it to a sealed box you prob going to have run round ports as slots would be to hard to add after the fact......also the volume of a ported box should be bigger so that may be a prob. dependant on how big your sealed is. anyways, decide on a tunning frequency calculat the port length, drop the tubes in seal them will silicon and your set.
well its 1 10 jl w3 in a box thats way too big (big enough for 2 subs) i would say about 1.5-2 sq ft, i like spl, so what should i want to tune it to? 35-40? its getting pushed by 500 watts at 2 ohms. Also where is the easiest place to get the round tubes?
Once you figure out what size port and how long
Go to a hardware store and get PVC pipe.
3" 4" 6" are the sizes you can get.
Buy it by the foot.
417
778
617
substance
substance
houston
ShaunMac
    May 16, 2024
    May 16, 2024
