gckless
So, thinking about doing PSI PR's with my 3HP's. I know I have seen that rule of thumb is have double the Vd in your PR's as you do in your powered drivers, but how much wiggle room is there? Can I get away with less? And there's no problem with doing different sized PR's in the same box, right? From what I understand, I just need to make sure each weighs what it should based on the tuning I want.
I'm also looking for info on ported vs. PR in the sound arena (I understand the immediate positive of space savings). How do they sound different? What stuck in my head when I was reading was "the sound of a sealed box, with the output of a ported box." I know this can't be entirely true. Was looking to see how they act at low/high tuning under power. I read they roll off at 28dB (PR) vs. 24dB (ported) under tuning.
So here is my ported box design:
Two 15" 3HP's run off a DC 5k. This box is tuned just under 30Hz. Would probably tune around 27Hz or lower with PR's. Most amount of Sd I could fit here is a 15" and two 12" PR's, but not sure that would be enough.
Reason I'm thinking about this, is that I'm trying for a great sounding decently loud setup, but the focus is on sounding good.
@TaylorFade I know you've played with PR's, what you got for me? @ciaonzo @keep_hope_alive
