Ported truck box
yes it is possible but it will have to be built specifically for your woofer. anything you can buy in stores will **** unless you can match its specs. my friend has a probox ported wooferbox and it sucks, my sealed box is pretty much as loud by earshot and my SQ is way way better
pick a woofer, find out how much space you have, calculate the space and see if the woofer will perform within that space available. if not, find another woofer. dont try to fit something ridiculous like two deep 15s in a reg cab, you WONT have enough airspace. once you find a combo that fits ask for help wiht a box
didnt you read my first post
i said i had 1 10" sub not 15s
Build your box around your sub. Guiness was just saying to not do something LIKE that(fit a 15 in your truck), not that you plan on actually doing it. http://www.bcae1.com is a good site for a free box volume calculator...so check your specs on the sub, and see if the space you have in your truck is a sufficient amount of space to make the RIGHT box with the correct volume for your sub. You will most likely have to build a sealed enclosure, but if you have enough length, you might be able to get away with it. the thing you do not want to do is rig a box to "whatever fits" inside your truck. you might get lucky and it sound good, but in most cases it sounds like your woofer is shitting all in your trunk. DO NOT take the newb's way out. make a box that "fits" your sub and do the **** thing
Nick
tmilla
MMMMMMM Cheese
tmilla
Wisconsin
tmilla
michigan born
    May 14, 2026
michigan born
    May 14, 2026
