Ported Fiberglass Boxes... Help
its quite complex and you will need to determine the volume b4 you build, if your doing a basic 2 side mdf and the rest glass, you will need to use the 2/3 rule which is how much volume you have inside compared to if that box was fully mdf, the fiberglass box would only be 2/3 the actual volume over mdf
or you could build the box, find the volume, then use areo ports cut to the desired length for the ports
I like the second option //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Its impossible to find out the volume before its built... its quite odd shaped, so I cant chance it...
Ill have to invest in some aero ports.
Best Place to Buy Aeroports?
Psyence
Customized
Psyence
Canada
bjfish11
